The Sensor
A notable characteristic of a silicon diode is its temperature sensitivity: the forward voltage decreases by approximately 2 mV for each 1 °C increase in temperature, exhibiting fairly linear behavior over the range of roughly 0 to 100 °C. Since the base-emitter junction of a transistor behaves like a diode, individual transistors can be conveniently used as simple and reliable temperature sensors.
Okay, let’s write an Arduino sketch that reads values from the ADC first. Since our XIAO board uses the SAMD21G18 MCU, it has a built-in 1.0 V reference, which we will use because it has about 1% tolerance and can provide reasonably precise measurements.
We also added a 1-Wire temperature sensor to calibrate our transistor-based sensor. The Arduino code is shown below:
#include <arduino.h>
#define OW_PIN 2
#define D0_PIN 0
#define A1_PIN A1
#define SAMPLE_INTERVAL_MS 200
#define PRINT_INTERVAL_MS 10000 // 10 sec
// Bus control
void ow_low() { pinMode(OW_PIN, OUTPUT); digitalWrite(OW_PIN, LOW); }
void ow_rel() { pinMode(OW_PIN, INPUT); }
int ow_rd() { return digitalRead(OW_PIN); }
bool ow_reset() {
ow_low(); delayMicroseconds(480);
ow_rel(); delayMicroseconds(70);
bool p = !ow_rd();
delayMicroseconds(410);
return p;
void ow_write_bit(uint8_t b) {
ow_low(); delayMicroseconds(b ? 6 : 60);
ow_rel(); delayMicroseconds(b ? 64 : 10);
uint8_t ow_read_bit() {
ow_low(); delayMicroseconds(6);
ow_rel(); delayMicroseconds(9);
uint8_t b = ow_rd();
delayMicroseconds(55);
return b;
void ow_write(uint8_t v) { for(int i=0;i<8;i++) ow_write_bit((v>>i)&1); }
uint8_t ow_read_byte() { uint8_t v=0; for(int i=0;i<8;i++) v|=ow_read_bit()<<i; return="" v;="" }="" uint8_t="" crc8(uint8_t="" *d,="" len)="" {="" crc="0;" for(uint8_t="" i="0;i<len;i++)" b="d[i];" j="0;j<8;j++)" m="(crc^b)&1;">>=1; if(m) crc^=0x8C; b>>=1; }
return crc;
// Accumulators
float voltageAccum = 0;
float tempAccum = 0;
int sampleCount = 0;
unsigned long startTime = 0;
unsigned long nextPrintTime = 0;
float readTemperature() {
uint8_t rom[8], scratch[9];
if(!ow_reset()) return NAN;
ow_write(0x33);
for(int i=0;i<8;i++) rom[i]=ow_read_byte();
if(crc8(rom,8) != 0 || rom[0] != 0x28) return NAN;
ow_reset();
ow_write(0xCC); ow_write(0x44);
pinMode(OW_PIN, OUTPUT); digitalWrite(OW_PIN, HIGH);
delay(750);
ow_rel();
ow_reset();
ow_write(0xCC); ow_write(0xBE);
for(int i=0;i<9;i++) scratch[i]=ow_read_byte();
if(crc8(scratch,9) != 0) return NAN;
int16_t raw = (scratch[1]<<8)|scratch[0];
return raw / 16.0f;
void printTime(unsigned long elapsedSec) {
unsigned int minutes = elapsedSec / 60;
unsigned int seconds = elapsedSec % 60;
if (minutes < 10) Serial.print("0");
Serial.print(minutes);
Serial.print(":");
if (seconds < 10) Serial.print("0");
Serial.print(seconds);
void setup() {
Serial.begin(115200);
while(!Serial) delay(10);
pinMode(D0_PIN, OUTPUT);
digitalWrite(D0_PIN, LOW);
// XIAO SAMD21: MUST set 12-bit explicitly — default is 10-bit!
analogReadResolution(12);
analogReference(AR_INTERNAL1V0); // 1.0V internal reference
startTime = millis();
nextPrintTime = startTime + PRINT_INTERVAL_MS;
nextPrintTime = ((nextPrintTime + PRINT_INTERVAL_MS - 1) / PRINT_INTERVAL_MS) * PRINT_INTERVAL_MS;
Serial.println("Time,Voltage[mV],Temperature[C]");
void loop() {
unsigned long now = millis();
// Sample every 200 ms
static unsigned long lastSampleTime = 0;
if (now - lastSampleTime >= SAMPLE_INTERVAL_MS) {
lastSampleTime = now;
// Read voltage: 1.0V ref, 12-bit ADC (0–4095)
int a1_raw = analogRead(A1_PIN);
float voltage = a1_raw * (1000.0 / 4095.0);
voltageAccum += voltage;
// Read temperature
float temp = readTemperature();
if (!isnan(temp)) {
tempAccum += temp;
sampleCount++;
// Print every 10 seconds
if (now >= nextPrintTime && sampleCount > 0) {
float avgVoltage = voltageAccum / sampleCount;
float avgTemp = tempAccum / sampleCount;
unsigned...
Sagar 001
Lithium ION
Coders Cafe
