Component List
Core Electronics
ESP32-WROOM-32 Development Board – main controller, Wi-Fi/Bluetooth enabled
TP4056 USB-C Lithium Battery Charger Module – charging and protection for single-cell Li-ion battery
3.7 V 2000 mAh Li-ion Battery – power source for the entire system
Motion System
2× N20 500 RPM DC Gear Motors – differential drive movement
Dual-Channel PWM Motor Driver (L298N / MX1508 / similar) – speed and direction control
Ball Caster Wheel – rear stabilizer for balance and smooth turning
Sensing & Feedback
4× VL53L0X Time-of-Flight Sensors – distance measurement and obstacle detection
1× Accelerometer Module (e.g., MPU6050 or ADXL345) – tilt, orientation, and motion sensing
Display & Interface
2× 0.96″ OLED Displays (128×64, I²C, 0x3C address) – one for data output, one for expressive eyes
I²C Bus Splitter / Multiplexer (optional) – for managing identical I²C devices
Power & Connectivity
On/Off Switch – inline power control between battery and load
JST Connectors / 2-pin Micro Connectors – quick battery and motor disconnection
Magnetic Pogo Pin Connector (planned) – for future charging dock interface
Structure & Mounting
Custom 3D-Printed Chassis – designed in Fusion 360, houses electronics and sensors
Mounting Screws, Standoffs, and Spacers – for securing components
Motor Mount Brackets – holds N20 motors in alignment
Sensor Mounting Plates – adjustable front and side sensor positioning
Wiring & Miscellaneous
Dupont Jumper Wires (Male–Female / Female–Female) – prototyping connections
Breadboard / Perfboard – for initial wiring layout tests
Heat-Shrink Tubing & Cable Wraps – for clean wiring and insulation
Optional / Future Additions
Battery Voltage Sensor Module – to monitor remaining power on OLED display
Buzzer / Speaker Module – for audio feedback or status tones
IR Receiver / Remote Module – for manual testing and control
Wi-Fi Dashboard (ESP32 Web Interface) – for live telemetry and debugging
Auto Docking Charger Pads – for autonomous recharge testing
Ad
bosko
JP Gleyzes
NotBlackMagic
