In this test, we tested the ElephantAI system with elephants . This was using TensorFlow & Keras (off-shelf), TensorFlow using Inception trained on ImageNet 2012 dataset (off-shelf). More importantly this included the new model we trained, adding our new classes of elephant, via transfer learning on off-shelf model (InceptionV3) using TensorFlow.
[under construction]
