So to keep costs down I'm trying using the pi zero at the moment.
- Raspberry Pi Zero W with Soldered Header / Male Header - 40 Pin (2 x 20) - Straight [$19.37]
- JustBoom Amp Zero pHAT Maximum output is 30 W (RMS) 55W (Peak) [$33.21]
- SD card
- Adafruit FONA 808 - Mini Cellular GSM + GPS Breakout [£50]
- Slim Sticker-type GSM/Cellular Quad-Band Antenna - 3dBi uFL [£3.50]
- Visaton Cabinet Speaker, 30W nom, 50W max, 8Ω [£21.06x2]
- SIM
- Sealed enclosures for speakers
Details for JustBoom Amp Zero speaker power requirements :
8Ω Speaker
Amp Gain 26dB
Supply Voltage(V) 24
Peak Power(W) 55
Max Power(W) 30
Supply Power(W) 75
So that will be awkward for batteries! And I don't even know if that will be loud enough!
