Vibe coding an assembler / disassembler
A project log for CPU running Basic
Celebrating 50 years of Tiny Basic by implementing a custom micro-coded 16/32-bit CPU that executes it directly (up to 100MHz)
zpekiczpekic • 11/23/2025 at 06:30•0 Comments
Note: the online utilities presented here are in progress, but the assembly part seems to be working, disassembler probably coming over the holidays, time permitting.
My goal is to extend the Tiny Basic somewhat, to make it a bit more powerful and/or align it with other Basic dialects. For example, this could mean addition of:
for all of the above - beside microcode changes - I also need to modify the interpreter itself, which is written in TBIL. To do that, obviously a TBIL assembler is needed. For this part of the project, to jump 50 years from 1976 (when Tiny Basic was introduced) to 2026 (almost there!) I decided to use some AI vibe coding. There are many such platforms, I am most familiar with Lovable. I created an online assembler / disassembler tool which allows TBIL source code to be assembled (2 pass) into binary / hex / vhdl file I could use to provide as code to the Basic CPU.
Steps to try out the assembler:
  1. Navigate to online app
  2. Download the original version of interpreter
  3. Modify the interpreter, syntax is pretty obvious (only change from documented interpreter is that I use comma between branch target and "text" strings)
  4. Copy and/or upload the *.tba file using the "Upload source..." button
  5. Click Pass 1 button (observe if there are any errors)
  6. If no errors, click Pass 2 button (observe the action log)
  7. Binary code in hex format should appear in .... Switch to "Disassembly" mode to reveal the download options in .hex, .bin or .vhdl formats
The source code of the app is here. All changes have been done by lovable dev bot, purely through "vibe coding". I did a similar vibe coding online tool about 6 months ago and I see certain improvements. At that time, often after changes there would be a build break. When I developed this new app, there was no build break at all.
Vibe coding is still just .. coding
What this means is that all the good coding advices still apply. Most notably, everything about planning and designing the app before writing the actual code. In this case the UX of the app is rather boilerplate, using a one-page layout with standard controls such as editable text boxes, file upload / download, resizable panels, buttons etc. The AI tool shines with this part (although the code it produces is still bloated and slow, requires targeted prompting to refactor it into a leaner implementation), but where it obviously needs serious prompting is the business logic. After all, there is no proliferation of TBIL assemblers from 40+ years ago it can learn from :-) I put effort to explain exactly what needs to be done for each line of source code in both pass1 and pass2 of the assembler. I also included some links for context. Therefore, when I asked it to implement assembly pass 1 and 2 it was "on rails" and fairly successful, with only minor tweaks needed.
The original text of the instructions I provided ("knowledge" in Lovable parlance) is below. I also asked it to extract it as markdown document file and check it in. I organized the "knowledge" into:
http://www.ittybittycomputers.com/IttyBitty/TinyBasic/TBEK.txt
https://hackaday.io/project/204482-celebrating-50-years-of-tiny-basic
DEFINITIONS USED FOR ASSEMBLY PASS1 AND PASS2:
octaldigit
octaldigit is single digit in range 0 to 7 (inclusive). Represents values 0 to 7
constant
constant is decimal, hex (prefixed 0X, valid digits are decimal and A, B, C, D, E, D), or binary (prefixed by 0B, valid digits are 0, 1) integer. If any of these are prefixed by '-' (minus sign) then value is 0-constant (evaluate as 2's complement integers)
expression
expression is a string of one or more constants with operators + - * / (integer division) % (integer modulo) between them.
Action when encountered: expression_value is evaluated by parsing the expression using common operation precedence which can be changed using parenthesis ( and ). If expression_value cannot be evaluated log error and stop processing.
"text" or 'text'
text is any number of characters (each character is 8-bit US ASCII) between single or double quotes. Empty text (nothing between the quotes) is not allowed and if detected generates error.
Action when text is detected: text_transformed string is generated from text using following rules:
last character in text is copied over by adding 128 to its ASCII code
if character sequence ^^ is detected, only single ^ is copied over to text_transformed
if character sequence A^ to Z^ is detected then single character is copied to text_transformed which equals ASCII code of upper case character minus 64 (so M^ is copied over as value 13)
otherwise each character is copied from text to text_transformed, verbatim without changing the case
length of text_transformed is count of characters, which is always >0 and equals the number of bytes to represent the string in standard 8-bit ASCII
:label
label is string that must start with : (colon) and contain up to 8 alphanumeric characters or _. Label cannot stand by itself on the line. Label cannot start with _ or number after the colon. Label must be at the beginning of the line to be valid, or not be present on the line at all.
Action when valid label is encountered:
label is upper-cased
label_dictionary is checked if key with value of the label exists, if yes log error and stop processing
label is added to label_dictionary as key (without the : character), and the value is a structure that contains line_number and org_value
//comment
comment is any string that starts with two consecutive / characters.
Action on comment: when encountered, comment is removed or ignored starting with first / onwards to the end of string or line, and processing continues on the remaining string.
target
target must be a valid key in the label_dictionary, otherwise error is reported and processing stops.
Action when target is detected: target_value is assigned to be equal to org_value stored in the label_dictionary entry under the target key. target_value is then checked to be in range 0 to 2047 (inclusive), otherwise log error and stop processing.
relativebranch
relativebranch must be a valid key in the label dictionary, or character * (asterisk). If relativebranch is * character then the relativebranch_value is 0. If relativebranch is a label, then there are 2 cases:
if org value of label is >= org value then relativebranch_value = org value of the label - current org value + 31.
if org value label is <= org value then relativebranch_value =  org value of the label - current org value + 31
In all cases if relativebranch_value > 63 or less than 0 then log error and stop processing.
forwardbranch
forwardbranch must be a valid key in the label dictionary, or character * (asterisk). If forwardbranch is * character then the forwardbranch_value is 0. If forwardbranch is a label, then the forwardbranch_value equals org_value of the label - current org_value - 1. If forward_branch value is >31 then log error and stop processing.
LSB(value)
returns (value AND 0xFF)
AND is a logical AND operation, check resulting value to be in range 0 to 255, if not log error and stop processing
MSB(value)
returns (value AND 0xFF00) / 256
PROCESSING OF EACH LINE WHEN EXECUTING ASSEMBLY PASS1:
copy current line (from loaded assembly file) to lineString
remove comment from lineString (see definition of comment)
remove leading and trailing blanks (space and tabs) from lineString
convert lineString to upper case except anything under single or double quotes (see definition of "text" and 'text')
if lineString is empty, stop processing
if lineString contains label, process label, remove label from lineString
validate that lineString is not empty, if it is the log error in activity log
Recognize following content in the lineString (UPPERCASE with optional parameters), action to take is below each. If the content does not match any of the below, log error in activity log with line number.
.ORG expression
org_value = expression_value. If the new org_value is less than previous, log error and stop processing
SX octaldigit
org_value = org_value + 1
NO
LB expression
org_value = org_value + 2
LN expression
org_value = org_value + 3
DS
SP
SB
RB
FV
SV
GS
RS
GO
NE
AD
SU
MP
DV
CP
NX
LS
PN
PQ
PT
NL
PC "text"
org_value = org_value + 1+ lengthOf(text_transformed)
GL
IL
MT
XQ
WS
US
RT
JS target
J target
BR relativebranch
BC forwardbranch, "text"
org_value = org_value + 1 + lengthOf(text_transformed)
BV forwardbranch
BN forwardbranch
BE forwardbranch
FS
FE
PROCESSING OF EACH LINE WHEN EXECUTING ASSEMBLY PASS2:
if lineString contains label, check that label exists as key in the label_dictionary (created in pass1). If not, log error and stop processing
Recognize following content in the lineString (UPPERCASE with optional parameters), action to take is below each. If the content does not match any of the below, log error in activity log with line number. Every instruction below writes 1 or more consecutive bytes to "machine code" binary array.
.ORG expression
Machine code not changed
SX octaldigit
Write byte (0x00+octalDigit) to machine code at org_value, increment org_value
NO
Write byte 0x08 to machine code at org_value, increment org_value
LB expression
Write byte 0x09 to machine code at org_value, increment org_value
Write byte LSB(expression_value) to machine code at org_value, increment org_value
LN expression
Write byte 0x0A to machine code at org_value, increment org_value
Write byte MSB(expression_value) to machine code at org_value, increment org_value
DS
Write byte 0x0B to machine code at org_value, increment org_value
SP
Write byte 0x0C to machine code at org_value, increment org_value
SB
Write byte 0x10 to machine code at org_value, increment org_value
RB
Write byte 0x11 to machine code at org_value, increment org_value
FV
Write byte 0x12 to machine code at org_value, increment org_value
SV
Write byte 0x13 to machine code at org_value, increment org_value
GS
Write byte 0x14 to machine code at org_value, increment org_value
RS
Write byte 0x15 to machine code at org_value, increment org_value
GO
Write byte 0x16 to machine code at org_value, increment org_value
NE
Write byte 0x17 to machine code at org_value, increment org_value
AD
Write byte 0x18 to machine code at org_value, increment org_value
SU
Write byte 0x19 to machine code at org_value, increment org_value
MP
Write byte 0x1A to machine code at org_value, increment org_value
DV
Write byte 0x1B to machine code at org_value, increment org_value
CP
Write byte 0x1C to machine code at org_value, increment org_value
NX
Write byte 0x1D to machine code at org_value, increment org_value
LS
Write byte 0x1F to machine code at org_value, increment org_value
PN
Write byte 0x20 to machine code at org_value, increment org_value
PQ
Write byte 0x21 to machine code at org_value, increment org_value
PT
Write byte 0x22 to machine code at org_value, increment org_value
NL
Write byte 0x23 to machine code at org_value, increment org_value
PC "text"
Write byte 0x24 to machine code at org_value, increment org_value
Write every byte of text_transformed starting with position 0, increment org_value after each write
GL
Write byte 0x27 to machine code at org_value, increment org_value
IL
Write byte 0x2A to machine code at org_value, increment org_value
MT
Write byte 0x2B to machine code at org_value, increment org_value
XQ
Write byte 0x2C to machine code at org_value, increment org_value
WS
Write byte 0x2D to machine code at org_value, increment org_value
US
Write byte 0x2E to machine code at org_value, increment org_value
RT
Write byte 0x2F to machine code at org_value, increment org_value
JS target
Write byte (0x30 + (0x07 AND MSB(target_value)) to machine code at org_value, increment org_value
Write byte LSB(target_value) to machine code at org_value, increment org_value
J target
Write byte (0x38 + (0x07 AND MSB(target_value)) to machine code at org_value, increment org_value
BR relativebranch
Write byte (0x40 + (0x3F AND LSB(relativebranch_value)) to machine code at org_value, increment org_value
Write byte (0x80 + (0x1F AND LSB(forwardbranch_value)) to machine code at org_value, increment org_value
BV forwardbranch
Write byte (0xA0 + (0x1F AND LSB(forwardbranch_value)) to machine code at org_value, increment org_value
BN forwardbranch
Write byte (0xC0 + (0x1F AND LSB(forwardbranch_value)) to machine code at org_value, increment org_value
BE forwardbranch
Write byte (0xE0 + (0x1F AND LSB(forwardbranch_value)) to machine code at org_value, increment org_value
FS
Write byte 0x25 to machine code at org_value, increment org_value
FE
Write byte 0x26 to machine code at org_value, increment org_value
Note that FS and FE are "extended" instructions, not present in original TBIL, but I needed them to implement FOR/NEXT loop in extended version. Out of total of 256 op-codes 248 are used in original TBIL (very high % of utilization!), 250 in extended, leaving 6 free. Out of these 6, 5 could be used for implementing additional statements, but 1 should be left as an "prefix", to allow 2 byte op-codes, similar to Z80.
