Simplicity is the key feature here. You don't need to make or buy a PCB, build it, or do much wiring.
Components:
Optional parts:
Operation
I had to write some C code, because the demo code from FTDI had the USB-to-I2C module driving a serial EEPROM. The I2C-to-PIO chip is significantly different. I wasted many hours trying to adapt the demo code before asking an AI bot what was wrong with my code. It quickly spotted what I had done, and gave me some working code. This was the most time-consuming task, which won't need to be done again.
I quickly wrote a short routine to test the I/O by driving an LED bar.
I then wired the port A to the PAL14L4 pins 1 to 8. Port B had the less-significant bits wired to the other PAL input pins and the most significant bits to the four outputs. With 14 inputs and 4 outputs, a single 16-bit IO module can only read 2 outputs at a time. I decided to read just one output at a time, because it was quicker to run the reader program four times (4 x 40 seconds) than to write more code.
My code read the outputs to an ASCII text file, for both the original PAL14L4 and my self-made GAL16V8. Comparing the files using the Linux diff command quickly identified which outputs were identical, and where they were not.
Then it was a matter of tweaking my logic expressions until the matched. Fortunately I had equations from a similar chip for another machine, which proved a good starting point. With a bit of intuition and several iterations, I successfully duplicated the original logic.
I have a device that should have been able to read the fuse maps directly, but for some reason it was not working for 2 of the four outputs. Hence I had to create this project to figure those out the hard way.
Advantages
Disadvantages
Cost
UMFT4222EV module about £15
MCP23017 module (or chip) a few pounds
Comparison with other methods
Reading by using a ROM socket adaptor
This is simple but does need a ROM reading device.
https://dreamjam.co.uk/emuviews/readpal.php
Tony Brewer's PAL14L4 Reader
This uses counters to drive the input pins and is specific to the Memotech
Needs building on prototyping board
The software is written in Z80 assembler.
http://www.primrosebank.net/computers/mtx/projects/pal_reader/palreader_build.htm
A QBASIC program for reading PAL outputs and automatically deducing the logic equations is mentioned, but I can't find it for downloading.
Ideas for future work
There is hobbyist demand for reverse engineering programmable logic from old machines to preserve them. The combinatorial chips are simple, but registered chips are usually harder. For example, the PAL chips in the Applix 1616 machine had their security bits blown and the original inventor has lost/forgotten the original equations. People have discussed trying 'brute force' analysis by bombarding registered chips with every possible combination of input and output states. This is not a trivial task, and a person who realised this was going to need to build something like a 68000 class machine. That's a lot of trouble to go to. I would opt for a small, fast and microcontroller board like a 40-pin STM32 module that can be bought for as little as £6.
The Raspberry Pi is able to drive an SPI bus from a DMA. This allows it to transfer data at video rates, to LCDs for example. This seems a tempting way of sending input patterns for the brute-force analysis technique, and testing the behaviour of logic chips.
