I use my logic reader to record the behaviour of programmable logic chips, with the aim of making replacements. So I eventually need to write and compile proposed PAL equations.
I use Linux on my home PC, and don't want to temporarily swap to Windows in the middle of a session.
There are some Linux programs for compiling PALs but I found them limited in devices compared with the Windows programs written by the chip manufacturers.
So I use Linux Wine to run the free Opal suite that runs under MSDOS. Nice and simple, no Windows GUI needed.
Open your Linux terminal and type the following command:
wine cmd
A new prompt will appear inside your terminal that looks like
Microsoft Windows 10.0.19043 Z:\home\keith>
This presents my home directory as a virtual DOS/Windows drive.
I keep my PAL programming work on a USB drive, on a USB expander with the USB dongle for my wireless keyboard and mouse. This is so I can move them all at once to my antique device-programmer and computer. NB I have to do this before switching it on, so Win98 detects them. Win98 will not detect them later on.
Now I have to make my USB drive look like a DOS drive to wine. The command winecfg will open a GUI. I have previously defined my MSDOS-formatted USB drive (named USBDOS, appearing as /media/keith/USBDOS) to be drive G: so I simply type G: and I am 'in' that drive.
I then type
cd DOS/opal/Applix_1616/logic
and I'm in a workspace.
I have had some issues with wine before, so I installed a program called DosBox.
Now any attempt to run a DOS program from Wine opens a DosBox window, briefly, then closes.
So I now open DosBox from my Linux Games options, and again a Z drive is shown.
Type:
mount [virtual-drive-letter] [path-to-linux-folder]which in my case is
mount d /media/keith/USBDOS/DOS
DosBox is annoyingly accurate in that it won't handle file/directory names longer than 8 characters. I can cd to OPAL but not to Applix_1616. It suggests I use Applix~1, and this works. I then cd to the logic directory.
From there I can run
..\..\eqn2jed.exe -d PAL16R8 1616_U5.EQN
Keith
