This project is ideal for learning embedded development fundamentals, including GPIO control, Wi-Fi connectivity, and FreeRTOS task management.
2. Development Environment Setup
2.1 Hardware Requirements
- BW20-12F development board ×1
- USB data cable
- Ubuntu virtual machine (VMware Workstation)
2.2 Software Environment
I am using Ubuntu 22.04, and the Ameba RTOS SDK has been downloaded to the desktop.
First, we must resolve a common issue: Python package installation timeout. Because the default PyPI mirror is overseas, the download is slow. So we first configure the Tsinghua University mirror:
pip config set global.index-url https://pypi.tuna.tsinghua.edu.cn/simple
After configuration, enter the SDK directory and initialize the environment: cd ~/Desktop/ameba/ameba-rtos
source ameba.sh
The first run will automatically install Python dependencies. Please wait patiently.
2.3 Fixing Serial Port Permission Issues
When using a USB serial port inside a virtual machine, the device may fail to be recognized. This is because a service called brltty (Braille device tool) occupies the USB port.
Disable it using:
sudo systemctl stop brltty-udev.service sudo systemctl mask brltty-udev.service sudo systemctl disable brltty.service
Then connect the USB device in VMware:
VM -> Removable Devices -> QinHeng Electronics CH340 -> Connect
Check whether the device is available:
ls -la /dev/ttyUSB*
Normally you should see /dev/ttyUSB0.
3. Project Directory Structure
I created a project folder under the SDK’s my_project directory:
mkdir -p ~/Desktop/ameba/ameba-rtos/my_project/wifi_led_component cd ~/Desktop/ameba/ameba-rtos/my_project/wifi_led_component
Project structure:
wifi_led_component/
├── CMakeLists.txt # CMake build configuration
├── include/ # Header files (optional)
├── wifi_led.h # LED & Wi-Fi control header
├── wifi_led.c # LED & Wi-Fi control implementation
└── wifi_led_example.c # Example main program
4. Code Implementation
4.1 CMakeLists.txt
This file instructs the build system on how to compile the project.
There are two sections:
- Public section: headers/macros available to other modules
- Private section: source files for this component only
At first, my source file path was incorrect. I put files in the root directory but wrote:
src/wifi_led.c
The correct configuration:
ameba_list_append(private_sources
wifi_led.c
wifi_led_example.c
4.2 GPIO & Header File Issues
I initially used many incorrect header files found online, such as: wifi_conf.h, osdep_service.h, etc., which caused compilation errors.
After checking the SDK, the correct headers are:
- wifi_api.h — Wi-Fi API declarations
- wifi_api_types.h — Wi-Fi type definitions
- wifi_api_event.h — Wi-Fi event definitions (though later I found event callback APIs were not available)
- PB17 — green LED
- PB18 — red LED
- PB19 — blue LED
- unused parameters → add (void)param;
- type mismatch → use for >span class="16"###s32
- header not found → verify #include
Search header files using:
find ~/Desktop/ameba/ameba-rtos/component/wifi/api -name "*.h" LED pin mapping on the board:
4.3 Key Points for Wi-Fi Connection
I encountered several issues when implementing Wi-Fi connectivity.
Issue 1: Struct initialization error causing crash
I initially used strncpy to copy the password into the struct, but password in...
Ai-Thinker
Dillon Nichols
Roman
Vasilis Ieropoulos
