Porting off of Android
A project log for Web based file manager
Graphical filesystem interface for headless devices
lion-mclionheadlion mclionhead 12/31/2025 at 23:550 Comments
The mane problem is the lack of ifdef in Java.  The mane WebServer.java class has 34 java includes & 5 android includes, but no easy way to swap out the android includes.  This depends on Stuff.java which is android heavy.  This was leaning towards a new platform class with wrappers for all the android bits or maybe making Stuff.java platform specific.  WebServer.java is such a mess, replicating it in its entirety would not be ideal.  Http is quite a mess, being a text protocol that mixes binary data with natural language, carriage returns, linefeeds, many different encodings of the same characters.
Having said that, WebServer.java is actually partially replicated in Ultramap https://github.com/heroineworshiper/ultramap.  The ultramap version is much simpler since it doesn't have full file management.
android.text.Html.fromHtml would be quite difficult to replicate in Java SE.  It was quite a struggle to translate between the many html character codes, but there could be a reduced functionality.  If only the test cases for that function were still around.
With most filesystem based devices, lions are just using NFS.  Only the raspberry pi zeros absolutely need a browser file manager.  Wifi isn't up to NFS, but those devices just aren't seeing any use.  They amount to 2 sound recorders.  Maybe they would see more use if they had a browser file manager, but they also need a way of announcing their IP addresses.  It typically involves getting in on a serial console & running ifconfig, in which case you might as well use scp.  Webphone works on a phone because phones can show their IP address & getting a console is a pain.  What might work is a good old browser bookmark, but a PC browser isn't the only client for webphone.
Webphone would allow a phone browser to manage & download files on all the embedded devices instead of just the sound recorders.  That could be a win.
The 1st step might be abstracting the android dependencies in the android version & testing it in android.
It seems android.text.Html.fromHtml just converts an html string from the upload textbox:
What *is* the wavefunction?.mp4
Into a string for java.io.File where the \&\#65290\;  is converted to charAt() value 65290
When it goes the other way, it uses its own encodeHtml function to convert the charAt values to &#; strings.  This function came from grok.
Helas, if A HREF points to a $#; encoded string, the browser doesn't send a GET request.  Neither can the browser handle % unicode encodings in the A HREF.  It only converts spaces to %20.  Fortunately, there was never a desire to download a funky filename using webphone.  The funky filenames play properly in the android programs.
Many grok prompts later, the standalone version was working.
The PC's filesystem could be accessed on the phone.  Pretty clumsy on a phone browser.  It defaults to a ridiculously small font & large textbox size for the editor even though it's fine on the PC browser.
