Cleanup And Optomization
A project log for Lunar Lander for the PDP-1
My PDP-1 Replica (PiDP-1) from Obsolescence Guaranteed has arrived and I want to do something cool with it.
michael-gardiMichael Gardi 10 hours ago0 Comments
I wanted to review the code I had written. When I started this project I was a complete noob to both the PDP-1 machine and assembly language. After about a month's effort I felt that I was beginning to "get it".
So I went back and reviewed an early piece of code, drawing the LEM, and sure enough there were a number of improvements to be had.
/ Draw the LEM based on an 18-bit by 18 word bitmap.
        OLD                                    NEW
                                               lac (400000
                                               dac bit
                                               lac bsx
                                               dac tmp
lbn,    lac .                          lbn,    lac .
        sza i                                  sza i
        jmp lt1                                jmp lt1
        dac bmr                                dac bmr     [-20]
        lac (400000
        dac bit
nb0,    lac bit                        nb0,    lac bit     [0]
        and bmr                                and bmr
        sza i                                  sza i
        jmp nb1                                jmp nb1
        lac bsx                                lac bsx
        lio bsy                                lio bsy
        dpy-i 4700                             dpy-i 4700
nb1,    lac bit                        nb1,    lac bit     [-10]
        sad (1                                 rar 1s
        jmp nrw                                dac bit
                                               sad (400000
        lac bit                                jmp nrw
        rar 1s
        dac bit
        lac bsx                                lac bsx
        add scl                                add scl
        dac bsx                                dac bsx
        jmp nb0                                jmp nb0
nrw,    lac lbn                        nrw,    idx lbn     [-50]
        add (1
        dac lbn
        lac bsy                                lac bsy
        sub scl                                sub scl
        dac bsy                                dac bsy
        lac scx                                lac tmp
        sub (4400                              dac bsx
        dac bsx
                                               jmp lbn
        lac (400000
        dac bit
        jmp lbn
I'm not going to go into detail on the code above. Suffice it to say that I'm pretty happy with the improvements. The important thing is the numbers off to the right. They represent the number of microseconds I was able to eliminate from the OLD code when creating the NEW. Both of course do exactly the same thing.
PDP-1 instruction have the following performance characteristics:
In the above code comparison the numbers on the right indicate the how many "microseconds" were removed from that block of the code (demarked by the labels). Another thing to consider is how any times that block of code will be executed when drawing the LEM.  The lbn and nrw blocks only execute once per row of the bitmap, while the nb1 code executes once per pixel. So the total savings for optimizing this code is:
(20 + 50) x 18 rows =          1,260 microseconds
10 x 18 columns x 18 rows =    3,240 microseconds
                               4,500 microseconds
4.5 ms every time the LEM is drawn which is about 10 times per second.  That doesn't sound like much but it leaves more time to draw the other pixels and thus reduce flicker (say).
