The scoring for Lunar Lander worked as follows:
Base Point Values
Points are awarded for every landing attempt based on the "softness" of the contact:
- Good Landing: 50 points.
- Hard Landing: 15 points.
- Crash: 5 points.
Landing Requirements
- To achieve a "Good" landing and avoid a crash, the lander must meet specific telemetry criteria:
- Vertical Speed: Must be below 15.
- Horizontal Speed: Must be below 31.
- Orientation: The module must be nearly vertical and centered on the landing pad.
Score Multipliers
Landing pads are marked with flashing multipliers (e.g., 2x, 3x, 4x, 5x). The base points from the landing quality are multiplied by the pad's value. Narrower or more difficult terrain typically features higher multipliers.
Fuel Bonuses and Penalties
Fuel acts as the primary resource and "time limit" for the game:
- Good Landings: Award a bonus of 50 fuel units.
- Crashes: Can result in significant fuel penalties or the immediate end of the game if fuel is depleted.
My next little goal here is to add the "flashing multipliers" to the screen. Since we are just displaying numbers and the letter x most of the code necessary to do this is already in place. Frankly the hard part was tweaking the coordinates used to display the multipliers so that they were directly under the target zone and centered.
Here is the code:
/ Draw the target values.
dtv, lac (565000 / First target 5x.
dac dgy
lac (436000
dac dgx
lac (5 / 5
dac num
jsp ddg
lac dgx
add (27000
dac dgx / x
jsp c16
lac (414000 / Second target 2x.
dac dgy
lac (557000
dac dgx
lac (2 / 2
dac num
jsp ddg
lac dgx
add (27000
dac dgx / x
jsp c16
lac (440000 / Third target 3x.
dac dgy
lac (637000
dac dgx
lac (3 / 3
dac num
jsp ddg
lac dgx
add (27000
dac dgx / x
jsp c16
lac (421000 / Fourth target 1x
dac dgy
lac (764000
dac dgx
lac (1 / 1
dac num
jsp ddg
lac dgx
add (27000
dac dgx / x
jsp c16
lac (514000 / Fifth target 4x.
dac dgy
lac (155000
dac dgx
lac (4 / 4
dac num
jsp ddg
lac dgx
add (27000
dac dgx / x
jsp c16
lac (661000 / Sixth target 5x.
dac dgy
lac (331000
dac dgx
lac (5 / 5
dac num
jsp ddg
lac dgx
add (27000
dac dgx / x
jsp c16
The task of aligning the target values is exacerbated by the necessity of expressing the starting positions in "screen coordinates" which means:
- dealing with a range of numbers in both x and y directions between -511 and +511,
- having to shift those numbers up to the top ten bits of the coordinate 18-bit word,
- and then converting those numbers to octal (my life experience programming was primarily decimal, hexadecimal, and binary).
But it got done.
But that's only half the battle. Now I had to make them blink. At first I dropped the call to display the flashing values in the "once a second" part of my main game loop but the flashing was too fast. I found it annoying and distracting. So I added an additional check for a 5 second interval and put the display flashing values code there.
/ Main loop.
fr0, load \ict, -1 / Loops about every 100 milliseconds.
lac sec / Get the second count.
sub (1 / Reduce by one.
sza i / Not Zero?
jmp dsc / No - Do the one second code.
dac sec / Yes - Save the new second count.
jmp acu / Continue with acceleration calculation.
dsc, lac (12 / Reset the second counter.
dac sec
/ Put second code here.
lac 5sc / Check the 5 second counter.
sub (1
dac 5sc / Save result.
sza / Is AC Zero?
jmp acu / No - Continue with acceleration calculation.
lac (5 / Yes - Reset 5 second counter.
dac 5sc
/ Put 5 second code here.
This produced a much better result IMHO.
Even though the code says a "5 second interval" right now the interval is more like 2-3 seconds since I have not "tuned" the loop by adding an ict delay value. The multiplier values are now blinking at about the same rate as an airport beacon, 20-30 times a minute. It "feels" right. This is good news because it means that the current code is running at more than 60 frames a second. So there is headroom as I add more features.
Michael Gardi
