I Spoke too soon ! heat !
A project log for USB <-> AVB 32x32 channel interface
BBbox field recorder needed a networking option and AVB USB was expensive.
ben-bilesben biles 3 hours ago0 Comments
the weather got warmer here in Japan and now the LDO overheats !
I am now running the board off a bench supply after blowing 2 LDO's !
I think the answer is to increase board size to 100x100mm for more ground plane and possible
add the power supply on a daughter card. were running 2 x XMOS chips and they get hot.
I will stress the DCDC convertor with a load and check its not over volt the LDO under dramatic
 load switching but I think its just heat !
Making a PCB as small as possible is not always the best idea , heat is a factor !
