STM32F103C8T6 Configuration Using CubeMX + HAL Library
Open STM32CubeMX and select STM32F103C8T6.
Enable two UART interfaces:
USART1
- PA9 → USART1_TX
- PA10 → USART1_RX
USART2
- PA2 → USART2_TX
- PA3 → USART2_RX
Select Asynchronous mode and enable UART interrupts.
Baud rate settings:
- USART1: 256000 bps
- USART2: 115200 bps
Note: Ensure the baud rate settings match the radar and voice module requirements.
UART Data Processing Rd-03D UART Data
The Rd-03D module communicates with external devices via UART (TTL level).
- Default baud rate: 256000 bps
- Data format: 1 stop bit, no parity
The radar outputs detected target information, including:
- X coordinate
- Y coordinate
- Target velocity
By default, the radar operates in single-target detection mode and must be switched to multi-target detection mode for this application.
Data Frame Format
Example data frame:
AA FF 03 00 0E 03 B1 86 10 00 68 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 55 CC
- Red section: Target 1 information
- Blue section: Target 2 information
- Green section: Target 3 information
In this demo, only presence detection is required, so it is sufficient to check whether valid target data exists in the corresponding frame.
6. VC-02 UART Data The VC-02 UART protocol is user-defined. Development resources and documentation can be found on the VC series official website:
https://docs.ai-thinker.com/voice_module
Below is a custom-defined UART protocol and voice command table. All UART outputs are in hexadecimal format.
7. STM32 Data Processing Logic
This implementation uses flag-based logic to process data, preventing repeated voice announcements when radar data is updated too frequently.
uint8_t RX_BUF[64] = {0}; // Receive buffer
uint8_t RX_count = 0; // Buffer counter
uint8_t RX_temp; // Temporary received byte
uint8_t Radar_1 = 0; // Target 1 flag
uint8_t Radar_2 = 0; // Target 2 flag
uint8_t Radar_3 = 0; // Target 3 flag
uint8_t Speaker_1 = 0; // Voice announcement flag for target 1
uint8_t Speaker_2 = 0; // Voice announcement flag for target 2
uint8_t Speaker_3 = 0; // Voice announcement flag for target 3
uint8_t Single_Target_Detection_CMD[] = {
0xFD,0xFC,0xFB,0xFA,0x02,0x00,0x80,0x00,0x04,0x03,0x02,0x01
}; // Single-target detection mode command (detects only one target)
uint8_t Multi_Target_Detection_CMD[] = {
0xFD,0xFC,0xFB,0xFA,0x02,0x00,0x90,0x00,0x04,0x03,0x02,0x01
}; // Multi-target detection mode command (detects multiple targets)
uint8_t SpeakerCMD_0[5] = {0x5A,0x00,0x00,0x00,0x00}; // No-target voice announcement command
uint8_t SpeakerCMD_1[5] = {0x5A,0x00,0x00,0x00,0x01}; // One-target voice announcement command
uint8_t SpeakerCMD_2[5] = {0x5A,0x00,0x00,0x00,0x02}; // Two-target voice announcement command
uint8_t SpeakerCMD_3[5] = {0x5A,0x00,0x00,0x00,0x03}; // Three-target voice announcement command
void HAL_UART_RxCpltCallback(UART_HandleTypeDef *huart) // Callback function, called when one frame of data is received
if (huart == &huart2)...
Ai-Thinker
microwavemont
Jarrod
surfingsteve
