DIY roVad Smart Switch Kit
A DIY 4-channel smart relay kit with MQTT, local control, and flexible integration for smart-home projects.
Build it. Control it. Enjoy it.
**Overview**
DIY roVad Smart Switch Kit is a 4ch IoT smart relay system designed for makers who want local and remote control, transparency, and full customization.
The device supports:
- Two-way MQTT communication
- Local AP mode (offline control)
- Remote Wi-Fi operation
- Relay timers
- Real-time status feedback
It works with systems like Home Assistant, Mosquitto, Adafruit IO, CloudAMQP and other MQTT-based solutions.
The project follows a philosophy of continuous improvement — like climbing a hill where the goal is not the top, but constant progress. Both the hardware and software continue to evolve, while the entire system can be controlled from a single app and used worldwide.
Based on feedback and available resources, future versions may include:6, 8, or 16 channel variants.
DIY roVad Smart Switch KIT is designed for users who prefer flexibility, customization, and full control over their smart-home system.
Kit Specifications
  • Enclosure (Box + Lid) -  80 × 96 × 40 mm
  • Microcontroller - NodeMCU V3 ESP8266 Wi-Fi Module - 2.4GHz only
  • Relay Board 4ch
    • Input:
      • VCC: Positive supply voltage (5V)
      • GND: Ground
      • IN1–IN4: Relay control port
    • Output:
      • Connect a load: DC 30V/10A, AC 250V/10A
  • Dupont F-F cables (10cm) – (Mirocontroller - Relay Board)
  • LED diode (5mm)
  • Screws (M3)
  • Operating Conditions:
    • Humidity ≤ 90
    • Temperature: 0°C to 40°C
  • Mobile App: roVad Smart
Features
  • 4 independent relay channels
  • AP Mode (offline, local control)
  • Wi-Fi Mode (remote control via MQTT)
  • LED indicator for mode and status
  • Relay timers for automated switching
  • Two-way Interactive Communication
    • Send commands via MQTT or the ROVAD Smart App on your phone.
    • The NodeMCU microcontroller responds immediately with real-time status or data.
    • You can request information such as:
      • Current relay states
      • Timer settings
      • Exact device time
    • This enables full interactive control and feedback, making the system more responsive and intuitive.
  • Compatible with ROVAD Smart Android App for dashboard control
  • Light and Dark Themes
  • Suitable for hobbyists, makers, students, and developers
Safety Notice
  • High-voltage AC (110–250V) can be switched. Take extreme caution.
  • Always disconnect power before assembly, wiring changes, or maintenance.
  • Manufacturer is not responsible for damages due to misuse or improper assembly.
  • If you are not experienced with electrical wiring, seek assistance from a qualified technician.
Two-way communication via the app allows real-time interaction with the microprocessor. Users can monitor relay statuses, time, and timers at any moment. We welcome your suggestions for new commands.
Roadmap
This project is part of a growing DIY smart home initiative. Future plans include:
  • Upgraded kits: 6ch, 8ch, 16ch versions
  • Continued roVad Smart App development with interactive elements
  • New commands and advanced automation
  • Community feedback integration
License & Disclaimer
  • DIY educational and development purposes only
  • Manufacturer assumes no liability for misuse, damage, or injury
  • Follow standard electrical safety practices
  • 1 × Enclosue Box 3D printed (PLA)
  • 1 × Microcontroller NodeMCU V3 ESP8266
  • 1 × Relay Board 4CH (6, 8, 16 in the future) Output - DC 30V AC 250V (10A)
  • 1 × Mounting accessories Led diode, F-F cables, Screws
  • 1 × roVad Smart App Unique app for DIY roVad Smart Switch KIT
  • Project Launched! ?
    Rovad • 12/16/2025 at 10:35 • 0 comments
    We’re excited to officially launch the DIY roVad Smart Switch Kit project! 🎉
    This 4-channel IoT smart relay system is designed for hobbyists, makers, and students who want full control, transparency, and local-first operation. You can pre-order the kit, follow development updates, and get hands-on with smart home automation.
    Follow this project to stay updated on:
    • Pre-order progress and availability
    • Assembly tips and tutorials
    • Upcoming features and improvements
    Your support and feedback will help shape the future of this living, evolving smart-home platform.
    Let’s build smarter homes together! 🛠️
View project log
