I love shopping for Christmas presents. People who peek at them early annoy the heck out of me. I decided to create a "Present Peeker Trap" to prove that my wife was looking at her presents early. Also, I have a YouTube channel and thought it would be a funny video.
The idea was to take an ESP-32 CAM board, have it record a video, then send a push notification to my phone with the evidence that somebody "peeked".
Github Repo
https://github.com/MatthewJones517/present_peekinator
Board Selection
I chose an ESP-32 CAM board because I REALLY wanted the video evidence. The entire premise of this project revolved around collecting the video "evidence".
The board worked well, but I did run into some pretty significant limitations.
- The camera that came with it was absolutely terrible. The pictures all had a purple tinge and were very underexposed despite having plenty of lighting. I replaced the camera with an OV5640 from Amazon and had significantly better results. If you're going to use this board, plan on replacing the camera.
- If you're using all the features (Camera, WiFi, SD Card) you're VERY limited on GPIO. I encourage you to check out the pinout before committing to the board.
Overcoming Limited GPIO
The issue is that I wanted to hook up a photo resistor and a buzzer to complete the "trap". Based on my setup, I had precisely one free GPIO pin.
I am profoundly not proud of my solution here. I added an Arduino Nano to control the buzzer and photo resistor. When the resistor detected the box was opened, the nano brought the one usable pin on the ESP32-CAM high.
Using an Arduino Nano for this was insane overkill and made powering everything more difficult than it needed to be. Had I to do over again I would have made a comparator circuit to pair with the camera board.
Recording Video
My original plan was to use MJPEG video for this, but I had playback issues, even on VLC. I decided instead to wrap the images in an AVI container format. This was new territory for me, but turned out to be less computationally expensive than I anticipated. The format is well documented, so it's just a matter of following the rules.
I did have a few issues with the board resetting itself due to brownout issues when recording video and saving to the SD card. This turned out to be dependent on the USB Power Bank I was using, however I did disable brownout detection to improve reliability.
Backend Management
Once the video was recorded I needed to get it up to the internet. I hate managing web servers so I used a variety of Firebase services.
The ESP-32:
- Uploads the video to Firebase Cloud Storage
- Sends the download url for that video to a Firebase Cloud Function
From there the cloud function:
- Records the download URL in Firestore
- Triggers a push notification to the Flutter app I wrote as a client.
For security reasons a unique upload link is generated every time I want to upload a video.
The Client App
I wrote a simple "Naughty List Notifier" app in Flutter. It displays a list of "present peekers" downloaded from Firestore. It tapping on one of them takes you to the video evidence of the "peek".
The excellent `media_kit` package for Flutter plays back the video nicely. I'm a Flutter dev in my regular job, so this whole portion of the project was pretty easy.
What I'd Do for a 2.0
If I'm going to have a two-board system, I'd like to play an actual audio file instead of just using an active buzzer. The buzzer sounds super annoying and isn't as "fun".
If I'm keeping the buzzer, I'd like to get rid of the second board and just use the comparator circuit.
I do believe I can probably do some stuff to shrink this down to a smaller package. Also, I'd like to explore options to increase battery life by putting the ESP32 in sleep mode.
Check Out the Video
As I said at the beginning I have a YouTube channel. If you'd like to check out the video of this in action...
Makerinator
Patrick LeBoutillier
[ E C C 0 ]
