The following example demonstrates how to implement VFS using LittleFS.
1. Create a file system BIN file using vfs.py
Package vgs_test.txt from the test directory into a BIN file.
Content of vgs_test.txt:
this is a vfs test. 2025.11.18
Command: vfs.py -t LITTLEFS -s 4096 -c 32 -dir test -out littlefs.bin
Actual command used:
~/mcu/Ameba-rtos/ameba-rtos/tools/image_scripts/vfs.py -t LITTLEFS -s 4096 -c 32 -dir test -out littlefs.bin
Output:
littlefs.bin has been successfully generated. args:
├─ type: LITTLEFS
├─ block_size: 4096
├─ block_count: 32
├─ image_size: 131072
├─ source_directory: test
└─ output_image: littlefs.bin
2. menuconfig Configuration
Enable the option: Enable VGS LITTLEFS
3. Application Code
Reference example:
/ameba-rtos/component/example/storage/vfs
1)fats.conf
# This file is generated automatically by:
# python menuconfig.py -s ../component/example/storage/vfs/fatfs.conf
CONFIG_VFS_LITTLEFS_INCLUDED=y // Use LITTLEFS
CONFIG_VFS_FATFS_INCLUDED=n
2)example_vfs.c
#include "ameba_soc.h"
#include "os_wrapper.h"
#include "vfs.h"
#include "example_vfs.h"
void example_vfs_thread(void *param)
rtos_time_delay_ms(3000);
char filename[] = "vfs_test.txt";
char path[128] = {0};
char buffer[32] = {0};
char *prefix;
FILE *finfo;
int res = 0;
(void)param;
RTK_LOGS(NOTAG, RTK_LOG_INFO, "\r\n====================Example: VFS====================\r\n");
prefix = find_vfs_tag(VFS_REGION_1);
DiagSnPrintf(path, sizeof(path), "%s:%s", prefix, filename);
finfo = fopen(path, "r");
if (finfo == NULL) {
RTK_LOGS(NOTAG, RTK_LOG_ERROR, "[%s] fopen() failed\r\n", __FUNCTION__);
goto exit;
res = fread(buffer, 128, 1, finfo);
if (res < 0) {
RTK_LOGS(NOTAG, RTK_LOG_ERROR, "[%s] fread() failed, err is %d\r\n", __FUNCTION__, res);
} else {
RTK_LOGS(NOTAG, RTK_LOG_ERROR, "[%s] fread() content, read buffer is %s\r\n", __FUNCTION__, buffer);
fclose(finfo);
exit:
rtos_task_delete(NULL);
void example_vfs(void)
if (rtos_task_create(NULL, ((const char *)"example_vfs_thread"), example_vfs_thread, NULL, 4096 * 4, 1) != RTK_SUCCESS) {
RTK_LOGS(NOTAG, RTK_LOG_ERROR, "\n\r%s rtos_task_create(example_vfs_thread) failed", __FUNCTION__);
prefix = find_vfs_tag(VFS_REGION_1); // Get the VFS1 tag
DiagSnPrintf(path, sizeof(path), "%s:%s", prefix, filename); // Build file path
finfo = fopen(path, "r"); // Open file
res = fread(buffer, 128, 1, finfo); // Read file
4. Flash Programming
For the VFS Flash region, the StartAddr and EndAddr configuration should follow: Actual end address = EndAddr + 1
Region | Address | Size (KB) | Description |
VFS | 0x083E_0000 | 128 | Used for file system |
5. Execution Result
UART output
The output shows that the system successfully reads the content of vfs_test.txt from the file system flashed from littlefs.bin, and prints it via the serial port.
Ai-Thinker
Elbert
Ronald Sousa
Edgaras Art
