Visualizing Netlist Connections on Inspector & Schematic Polishing
A project log for PCB ReTrace
Browser-based PCB reverse engineering suite. Digitize boards from photos, map components, trace nets, and stitch images. 100% Local-first.
dev-labdev-lab 6 hours ago0 Comments
Just pushed another set of updates to PCB ReTrace. The biggest highlight is a new feature for the Inspector view: netlist connections are now visualized directly on top of physical PCB photos.
Visual Connectivity in the Inspector
Up until now, you could trace nets, but verifying them required jumping back and forth. Now, the Inspector can draw connection lines directly overlaid on your board photos.
Schema ReTrace Improvements
Alongside the Inspector view, the built-in schematic editor was polished with several workflow upgrades:
Bug Fixes
Try it out here: https://pcb.etaras.com/studio.html
