01 AI-Thinker Ai-SG Series
Not just a “wireless module”, but an ultimate RF front-end module
The Ai-SG01 / Ai-SG01-P are based on Panqi Micro’s next-generation PAN3120 RF chip, designed for industrial and IoT scenarios with extremely high requirements for size, performance, and stability.
- Frequency bands: 420–445 MHz, 470–510 MHz (optional)
- Receiver sensitivity: –121 dBm
- Transmit power: +20 dBm
- Size: 12 × 13 × 2.4 mm
- SMD-16 / castellated (stamp-hole) interface
Its core advantage lies in extreme miniaturization combined with top-tier RF performance.
02 Ai-SG01
The ceiling of RF performance in an ultra-miniature form factor
“Ultra-small” packaging capability
Ideal for:
- High-density PCBs
- Space-constrained terminals
Small size, high RF performance
Through system-level optimization of:
- Power amplifier (PA)
- Low-noise amplifier (LNA)
- Filters
- Peripheral matching networks
Ai-SG01 achieves maximum performance in a minimal footprint:
- Max transmit power: +20 dBm (100 mW)
- –121 dBm @ 2.4 kbps
- –107 dBm @ 50 kbps
- –103 dBm @ 100 kbps
- –94 dBm @ 500 kbps
Low power consumption
- Sleep current as low as 300 nA
- Wide supply voltage: 1.8–3.8 V
- Supports duty-cycle RX/TX
Ideal for:
- Wireless sensors
- Battery-powered terminals
- Medical wearable devices
Module Features
- Ultra-compact 12 × 13 × 2.4 mm, SMD-16 package
- Frequency bands: 420–445 MHz, 470–510 MHz (selectable via HW/SW)
- Max TX power 20 dBm (100 mW), supports DPC –20 to 20 dBm, 1 dB step
- RX sensitivity:
- –121 dBm@2.4 kbps, –107 dBm@50 kbps, –103 dBm@100 kbps, –94 dBm@500 kbps
- Low spurious emission design: harmonic suppression ≤ –60 dBc (2nd/3rd harmonics), compliant with CE / FCC
- Low ACPR: built-in predistortion engine ≤ –55 dBc at +20 dBm (50 kbps FSK)
- Default data rate 2–500 kbps; optional 2 kbps–2 Mbps or 2 kbps–4 Mbps (three ranges, configurable)
- Industrial-grade design: –40 to +85 °C (optional –40 to +105 °C)
- Rich interfaces: 4-wire SPI, 3-wire SPI, 5 GPIOs
- Wide voltage supply: 1.8–3.8 V (LDO mode)
- Sleep current down to 300 nA
- Special features: RSSI & LQI, AFC, built-in 32 k RC clock & external 32 k crystal, duty-cycle RX/TX, auto-ACK
- Supports whitening, FEC, CRC, Manchester coding
- Castellated (stamp-hole) interface for easy integration
03 Ai-SG01-P
Industrial-grade module built for range + power
Solves thermal accumulation risks during long-term high-power operation
One of the key highlights of Ai-SG01-P:
- PAE up to 41>#/span###
- Continuous transmission at 30 dBm
- Module surface temperature only 32–45 °C
- Antenna impedance mismatch protection
- Stable operation under no-load and abnormal conditions
Completely solves the long-standing “antenna burns the module” problem
Designed specifically for real industrial environments:
Even when:
- Antenna is not connected
- Antenna is mismatched
- Misoperation occurs on site
- The module continues to operate reliably.
Module Features
- Size 17 × 16 × 3.2 mm, SMD-16 package
- Max TX power 30 dBm (1 W) @ 3.3 V @ DPC 30 dBm, supports DPC 7–30 dBm, 1 dB step
- RX sensitivity –113 dBm @ 50 kbps
- Low spurious design: at full power (30 dBm), harmonic suppression ≤ –70 dBc (2nd/3rd harmonics), compliant with CE / FCC, solving excessive spurious emissions of traditional high-power modules
- Low ACPR: built-in predistortion engine ≤ –55 dBc at +30 dBm (50 kbps FSK)
- PAE up to 41>#/span### (@30 dBm, 25 °C, 24 h); surface temperature 32–45 °C, no thermal accumulation risk in long-term operation
- Antenna impedance mismatch protection prevents module damage due to missing or mismatched antennas
- Default...
Ai-Thinker
Yiğit
