Cheap Yellow Display & 2 Way 18650 Shield
Mounting Brackets for CYD & 2 Way 18650 Battery Shield
This project provides simple, 3D-printable mounting brackets designed to join a Cheap Yellow Display (CYD) with a standard 2 Way 18650 Lithium Battery Shield.
The goal is to create a compact, portable unit suitable for handheld projects, IoT controllers, or mobile dashboards.
Supported Hardware
* Display: ESP32-2432S028R (Cheap Yellow Display / CYD)
* Power: 2 Way 18650 Lithium Battery Shield
Files
* You can find the STL filefor the bracket under the files tab.
Assembly Notes
1. Printing: Recommended material: PLA, PETG, or ABS.
2. Hardware: Designed for use with standard M3 screws, nuts and spacers.
3. Wiring: Wire the 5V output from the battery shiled to VIN on the CYD.
4. Access: The design allows for access to the expansions ports and the SD card slot.
*Created for the maker community. Feel free to modify and adapt for your specific needs.*
CYD_2x18650_Shield.stl
Standard Tesselated Geometry - 65.12 kB - 12/26/2025 at 15:59
Download
