PumpLink is an open-source backend service written in Golang that enables remote, scheduled, authenticated control of motor pumps (or any device) via MQTT and REST APIs. It automates decades-old motor pumps turning them into IoT-ready, controllable devices.
Backend Language & Frameworks
Golang (Go): Core programming language used for the entire backend service.
Gin Web Framework: Fast and lightweight HTTP router for building REST APIs.
Security & Authentication
JWT Authentication: Secures all protected endpoints (login, device control, schedules).
Role-Based Access Control: Admin role with elevated privileges.
Password hashing for secure credential storage.
Core Features
User Management
Registration & Login: HTTP endpoints for user account creation and JWT token issuance.
JWT Protected Endpoints: Auth middleware guards user-specific actions.
Device Activation & Control
POST /api/activate-device: Queue system accepts device activation requests with duration.
Queue & Async Processing: Activates devices in the background with thread-safe quotas.
Device State Tracking: ON/OFF state stored in database with logs.
Session & Logging
Device Sessions: Sessions track periods when a device is ON (start/end, duration).
Device Logs: All ON/OFF events logged for audit-ability.
Scheduling
Scheduled Activations: Users can schedule future activations.
Priority Queue Scheduler: Uses a min-heap (priority queue) to trigger activations at correct times while maintaining concurrency safety.
MQTT Integration
MQTT Broker connection for real-time device control/commands.
Centralised topic definitions & helper services.
Real-Time Updates
WebSocket Service: Real-time device status broadcast to clients authenticated via JWT.
Ensures connected clients get instant device status updates on change.
Admin & Safety Controls
Force Shutdown API: Admins can stop running device activations instantly.
This supports safety & override capability if needed.
Push Notifications
Integration with Expo Push for mobile client notifications when devices activate.
Includes token registration and deduplication logic.
Database
PostgreSQL as the primary data store.
Uses GORM ORM for database interactions. GitHub
ERD diagram included (ERD.png) showing relationships: users, devices, sessions, logs.
Unique Technical Benefits
✔ Async control queue prevents blocking and supports safe concurrency.
✔ MQTT + REST + WebSockets blend real-time and structured control.
✔ Schedule + quota + safety overrides provide robust pump automation.
✔ Fully open source and modular for extension (UI apps, firmware).
How It Works (High-Level)
User logs in → receives JWT
Client sends device control (activate/schedule)
Backend enqueues and processes requests asynchronously
MQTT broker signals physical IoT device (pump controller)
WebSockets notify UI clients of status updates
Musab Gulfam
Andrei D.
AccidentalRebel
