Some recent developments are the file upload script and the memory dump converter.
File upload script
The file upload script allows for uploading assembly source files without drop-outs. The monitor uses a software UART, and this is essentially half-duplex. Every now and then the editor needs some time to organize the incoming data and if the host doesn't wait, characters get lost. The monitor uses the DTR pin to signal this. The host in my case is a Linux machine and this supports only hardware handshake on the CTS/RTS lines. With the EVM-DTR connected to the host-CTS, the data-upstream stream is properly controlled. No hardware handshake is needed for the EVM to host direction.
The Sparkfun FT232RL breakout board and clones supports hardware handshake on the CTS/RTS and DSR/DTR pin pairs.
EVM7000-3 P1 Sparkfun FT232RL GND 6 GND Tx 5 Rx Rx 3 Tx DTR 2 CTS
See: https://electrickery.nl/comp/tms7k/t7k_em/emvUploader.py
GND 6 GND
Tx 5 Rx
Rx 3 Tx
DTR 2 CTS
Memory dump format converter
The EVM7000 supports two memory dump formats, a Texas Instruments format and the Tektronix format. The T.I. format was developed for the TMS9900 16-bits architecture and adapted for the 8-bits TMS7000. The Tektronix format is less popular than Intel-Hex or Motorola-S19, but converters do exist. I couldn't find a converter for the T.I. format, so made one myself. Currently it only converts from T.I-format to Intel-Hex and ignores the original checksums. Have to fix that as it is a precondition for the reverse converter.
The format uses prefix letters for a fixed number of data characters. 'B' is for instance always followed by two data bytes, hex encoded. '9' is always followed by two address bytes. Using the same characters for prefix and data is confusing, but parseable.
See: https://electrickery.nl/comp/tms7k/t7kDump2hexIntel.py
Addendum: Fixed an issue with the Intel-Hex checksum and figured out the problem with the TMS7000 format checksum. The checksum is calculated over all chars excluding actual checksum and 'F' postfix, not all characters between <CR>s.
fjkraan
