Printing...
A project log for JDC34 Camera
This is another camera body based on Raspberry Pi HQ Cam
jacob-david-c-cunninghamJacob David C Cunningham 01/19/2026 at 00:250 Comments
Yeah these pieces are pretty complicated/need a lot of support. The front half takes 13.5 hrs to print and the back half takes 11 hrs to print plus the display holder which is another 2 hrs to print.
I've already interfaced with all the electronics see below.
So it's a matter of assembling it once I have the plastic parts printed out.
It does look a lot different from what I initially imagined. I had to conform to the part dimensions.
Also I did change my mind later and wanted something that looked like this:
With an emphasis on the tiny vintate cine lenses.
But yeah it ended up looking bulbous which is from using SketchUp as it's hard to design round things. Anyway this camera will use an updated menu I'm working on. Which uses JSON-based menu interfaces and state-rendering like React. That's what I say anyway, that's just the visual aspect, I have to port the current camera code over to Pelicam. I recently added shutter delay for telephoto.
I've been buying a lot of random old C-mount lenses it's been fun.
Recently I took this one out.
