Intel 4004 Microprocessor Recreation
A cycle-accurate recreation of Federico Faggin's pioneering 4004 microprocessor in open-source silicon, alongside modern evolutionary architectures.
Real die shot of the historic Intel 4004, the world's first microprocessor
🎯 Project Goals
This project recreates the complete Intel MCS-4 system while simultaneously exploring the "what ifs" of computer architecture history. The goals are:
- Historical Preservation: Document and preserve the 4004's architecture for future generations
- Evolutionary Exploration: Design pipelined and RISC variants to demonstrate architectural progression
- Education: Provide a working, understandable example of early microprocessor design
- Physical Silicon: Manufacture actual working chips through Efabless/SkyWater
📖 The Story
The Intel 4004, designed by Federico Faggin in 1971, was the world's first single-chip microprocessor. It contained 2,300 transistors and enabled the microcomputer revolution.
This recreation honors Faggin's pioneering work by bringing his design into the modern era of open-source silicon. I am traveling to Italy to visit Olivetti (where Faggin started his career), his hometown of Vicenza, and to study the history that led to this revolutionary chip.
For a more detailed look check out the repo
🧪 Experimental Cores
Beyond the faithful recreation, this project includes two novel cores that explore alternative histories and modern design principles:
Core B: Pipelined 4004 ("The What-If")
A high-performance reimagining of the 4004. It asks the question: If the 1971 engineers had a larger transistor budget, how fast could they have made this chip?
- Architecture: 5-Stage Pipeline (Fetch, Decode, Execute, Memory, Writeback)
- Datapath: Full 4-bit parallel execution (replacing the original serial ALU)
- Compatibility: 100% binary compatible with the original 4004 ISA and bus
- Performance: Targets significantly higher IPC (Instructions Per Cycle)
Core C: RISC-4
A clean-slate, novel 4-bit architecture designed for modern efficiency and compiler friendliness.
- Architecture: 5-Stage Pipeline with Von Neumann memory model
- ISA: Custom fixed-width RISC (Load/Store architecture)
- Features: Simplified control logic, unified memory bus, and modern hazard handling
- Specification: View the RISC-4 ISA Repo →
Jeremy King
Joshua M. Thompson
maker2222
Sonal Pinto
This is cool! Good Luck!
