Quick fix actually work
A project log for RotoPD Pro - USB-C 240W Breakout I2C
Advance Power Delivery trigger that is designed up to 48V. The full 240W range of USB PD 3.1 with EPR and AVS!
centylabCentyLab • 03/20/2026 at 07:03•0 Comments
Swapping out the 3.3V -> 5V level shifter IC just solve this GitHub issue. We also need to swap out 2 (two) other resistors as the calculation was not correct. Basic functionally is working now!
Next step: Firmware development!
