First try!
A project log for RotoPD Pro - USB-C 240W Breakout I2C
Advance Power Delivery trigger that is designed up to 48V. The full 240W spec of USB PD 3.1 with EPR and AVS!
centylabCentyLab 03/14/2026 at 04:000 Comments
Our first design was able to pull 48V like expected without anything blowing up!
However, the voltage level shifter doesn't solve the leaking current issue, mentioned in this GitHub issue. We are working to replace this part with footprint compatible parts.
