Log 1: Observability & Dynamic Schema Management
A project log for ProtoMQ: Type-safe, bandwidth-efficient MQTT.
MQTT + ProtoBuffers + Ziglang. Stop sending bloated JSON over the wire.
gkhan-komarlgökhan koçmarlı 02/23/2026 at 01:250 Comments
One of the biggest pain points in using Protobuf with MQTT is the rigidity of the message types. In a standard setup, if you want to change a schema, you often have to rebuild and restart the broker. Not with ProtoMQ.
We've just implemented an optional HTTP Admin Server that brings operational visibility and hot-schema updates to the broker without touching the "hot-path" of message routing.
What’s New?
Why this matters for IoT?
Debugging a distributed fleet of sensors is hard enough. By adding standard HTTP-based monitoring and schema management, we've made ProtoMQ ready for production environments where "set and forget" isn't an option, all while maintaining our sub-millisecond latency targets.
