Hackaday.io Hackaday.io
Sign up Log in
5x7 RGB led Display
5x7 RGB LED display using 2020 surface mount rgb addressable leds with the Arduino ATtiny microcontroller, chain-able on I2C control.
harold-mooreHarold Moore
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1 comments
0 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 1
View Gallery
88
1
0
0
Team (1)
  • harold-mooreHarold Moore
Join this project's team
ongoing project
RGB LED PCB
This project was created on 02/03/2026 and last updated a day ago.
Description
Here on this unit I've yet to clean off the flux, but is working very well, soldering is very difficult without a metal positioning mask, but is on my to-do list. VCC, the RX an TX serial lines, programming pin (UPDI), I2C bus communication pins (SDA + SCL), and the ground pin are all shown. What makes this "yet another rgb pcb" better than the rest is its fast refresh rate, not using a single data line for all leds, but seven! So each signal line has just five rgb leds on it. In the future I plan on using two of these display boards with an ESP32 C6 system, I will call it the "Radio Badge" project. In the two videos below I have a vertical/horizontal program running, and ALSO an A/D running a level meter with random input, but using the A/D function, so you can see the refresh capabilities.
Details
Log In/Sign up to comment
Sign up with Github
OR
Phil Weasel wrote 20 hours ago • point
Aaaaw yiss, tinys for the win! Love this kind of stuff.
What are the vias on the bottom used for? Are they gnd-Connections? Otherwise you could use SMD-pins and move everithing below the LED´s to make it a cleaner appearence.
An Arduino based Scrolling Text Display built using 7 x Bi-color LED Matrix modules daisy-chained together (Bluetooth + Android)
Project Owner Contributor
Arduino (SPI) 7 Bi-color LED Matrix Scrolling Text
nick-limNick Lim
Easily connect several 7-Segment displays using a single wire to your microcontroller.
Addressable 7-Segment Displays
sean-hodginsSean Hodgins
The 2016 Hackaday Prize
A small gadget that reminds you to bring an umbrella
MyForecast
jareklupinskijareklupinski
Timepieces built using vintage HDSP-2000 LED displays
Retro Time: dot matrix LED clocks
patrick-hickeyPatrick Hickey
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "5x7 RGB led Display", please tell us the reason.
Send message
Remove Member
