The following animated image demonstrates how to select the target processor, configure the debug interface, load an ELF file, and download the code.
Note that the image also shows the TAB-based auto-completion for device part numbers.
A project log for Debugger Dedicated to Embedded Systems
Compact Debugger is an embedded-specific debugger written entirely in pure C, designed for efficiency and low resource usage.
