Setting breakpoints
A project log for Debugger Dedicated to Embedded Systems
Compact Debugger is an embedded-specific debugger written entirely in pure C, designed for efficiency and low resource usage.
chaostangCHAOS.TANG 02/06/2026 at 09:290 Comments
The following animated image demonstrates breakpoint placement using both the command-line and graphical interfaces.
