Code viewer
A project log for Debugger Dedicated to Embedded Systems
Compact Debugger is an embedded-specific debugger written entirely in pure C, designed for efficiency and low resource usage.
chaostangCHAOS.TANG • 02/06/2026 at 10:26•0 Comments
The following animated image demonstrates how to use the code viewer.
The code viewer provides two operating modes:
The code viewer allows you to select and open specific source files. It supports opening header files included by C source files and enables direct function navigation.
Within the code viewer, the assembly code corresponding to C statements can be expanded and collapsed.
In addition, the code viewer provides an advanced state-preserving navigation feature. You can open multiple source files, navigate between them, and expand or collapse C statements. When navigating back to previously viewed files, all prior viewing states and operations are automatically restored.
You can also place breakpoints and perform Run-To operations directly within the code viewer.
