I have a Youtube video about this project and this is the Intro, Part 1: Program Counters, and Part 2: Registers
An 8th grader designing and building a real 8-bit CPU from scratch using custom architecture and discrete logic.
instr.txtInstruction set and microcodeplain - 4.73 kB - 02/06/2026 at 22:56 |
CPU_4.0.digMain CPUdig - 326.08 kB - 02/06/2026 at 22:56 |
ALU_V2.digmain ALUdig - 83.19 kB - 02/06/2026 at 22:56 |
instr-data.hexThe stored hex format of thehex - 67.56 kB - 02/06/2026 at 22:56 |
Stack_FOR_MIT.digStack for the CPUdig - 22.27 kB - 02/06/2026 at 22:56 |
YES! The FPGA works! It didn't work because I used one of the MODE pins as a normal I/O and when I would boot it it would not boot my program. I also changed the switches to just wires because that way I wouldn't have to worry about pull-down resistors.
Please comment or follow! Thanks!
So the ALUI doesn't exactly work. I took the FPGA I was using and put it into a testing circuit. I'm testing it and it doesn't work. Trying to fix it hopefully I will find a solution sometime soon! If you have anything to say please comment! Thanks! Here's a picture:
I finally finished building the ALU part! Here's a picture. The FPGA in the middle does addition, subtraction, complement, and, or, xor, and shifts. The rest off the chips are buffers, comparaters, registers, and the A register. The eight LEDs are connected to the data bus. If you have any suggestions please comment! Thanks!
That’s absolutely amazing for your age!
