8-Bit CPU from SCRATCH
An 8th grader designing and building a real 8-bit CPU from scratch using custom architecture and discrete logic.
I started this project to understand how real CPUs work. After making my first 4-bit CPU I started reading about the 8085, z80, and the 6052. I wanted to design a faster CPU than those. Right now my CPU can run instructions in less cycles, but it can't run on a super fast clock and doesn't have some of the powerful block transfers that the z80 has. I designed the CPU from scratch using TTL chips and a ROM for the instruction decoder.
The CPU has a custom instruction set with over 60 instructions. Its ALU can do over 8 operations including: ADD, SUB, Complement, compare, shift, etc. It has 4 general purpose registers and 4 for special purposes. The CPU can address 128 kilobytes of RAM and ROM. Its stack can store sixteen 16 bit wide data so it can call 16 times and be able to return.
If you want more hardware info, check out my github link and my youtube channel. This project is still in progress as I am making the ALU part. Logic designs simulated using Digital by H. Neemann.
I have a Youtube video about this project and this is the Intro, Part 1: Program Counters, and Part 2: Registers
instr.txt
Instruction set and microcode
plain - 4.73 kB - 02/06/2026 at 22:56
Download
CPU_4.0.dig
Main CPU
dig - 326.08 kB - 02/06/2026 at 22:56
Download
ALU_V2.dig
main ALU
dig - 83.19 kB - 02/06/2026 at 22:56
Download
instr-data.hex
The stored hex format of the
hex - 67.56 kB - 02/06/2026 at 22:56
Download
Stack_FOR_MIT.dig
Stack for the CPU
dig - 22.27 kB - 02/06/2026 at 22:56
Download
  • ALU works!
    Bohan Xu03/15/2026 at 21:10 0 comments
    YES! The FPGA works! It didn't work because I used one of the MODE pins as a normal I/O and when I would boot it it would not boot my program. I also changed the switches to just wires because that way I wouldn't have to worry about pull-down resistors.
    Please comment or follow! Thanks!
  • Testing ALU
    Bohan Xu03/13/2026 at 21:41 0 comments
    So the ALUI doesn't exactly work. I took the FPGA I was using and put it into a testing circuit. I'm testing it and it doesn't work. Trying to fix it hopefully I will find a solution sometime soon! If you have anything to say please comment! Thanks! Here's a picture:
  • Finished building ALU!
    Bohan Xu02/18/2026 at 01:22 2 comments
    I finally finished building the ALU part! Here's a picture. The FPGA in the middle does addition, subtraction, complement, and, or, xor, and shifts. The rest off the chips are buffers, comparaters, registers, and the A register. The eight LEDs are connected to the data bus. If you have any suggestions please comment! Thanks!
View all 3 project logs
MCUer wrote 02/08/2026 at 15:48 point
That’s absolutely amazing for your age!
Bohan Xu wrote 02/08/2026 at 20:45 point
Thanks!
Ken Yap wrote 02/07/2026 at 21:59 point
Should be interesting. More power to you! 👍
