Having found a 4G phone on GQRX I'm now taking it to another piece of software that can eventually pull a list of register settings to be uploaded to an Arduino for control of the LimeSDR repeater via SPI when/if it actually starts to work properly!
Problems that I discovered in this test is that the receiver gain on channel B is set way too high and that the bandwidth of the whole system is probably set a bit too low.
