The animation below shows really clearly the noise created and the loss of signal incurred when the CTS USD020 duplexer is used. For comparison, when the duplexer, which is basically a pair of band filters, is used I ramped up the LNA (low noise amplifier) by 4 dB. This is not necessarily bad as the advantages of having a reasonably good band pass filter are enormous.
