Alloy drilling and planetary direct drive
A project log for Three-Chamber Rotary-Valve Pulsed Combustion Demon
Three-chamber pulsed combustion demonstrator using a rotary valve and Hall sensors to mechanically sequence ignition and fuel.
graemeGraeme 5 hours ago0 Comments
I am in the process of using the lathe to get flat surfaces, then pilot drill all holes and fabricate a hole saw  type tool to cut the oring grooves in the alloy.
I have made a 3d Printed planetary Direct drive motor holder  with D drive for thr rotor shaft.
