v1.0.0 — Architecture Mode and Smarter AI
A project log for Codedocent — A Guided Tour of Any Codebase
An interactive visual map of any codebase with plain English explanations. Built for non-programmers.
brandonBrandon 02/20/2026 at 03:140 Comments
The original Codedocent showed you code structure from the bottom up: functions inside files inside directories. That's useful for drilling into specifics, but it doesn't answer the first question most people have: how does this whole thing fit together?
Architecture mode answers that question.
What's new
Run codedocent /path/to/code --arch and instead of nested blocks, you get a dependency graph — a visual map showing which modules depend on which. Files are nodes. Import statements become arrows. Tightly coupled code clusters together; isolated utilities drift to the edges. You can see at a glance what's foundational and what's peripheral.
Three zoom levels:
There's an "Export MD" button at each level that generates structured context you can paste into any AI tool for deeper analysis.
Smarter AI summaries
The AI analysis got a major upgrade. Previously, each file was explained in isolation. Now the prompt includes dependency context — what this file imports and what imports it. The AI understands role: is this a foundation that everything else builds on, or a leaf utility that nobody depends on?
Summaries now include a KEY CONCEPTS section listing the main functions, classes, and data structures with one-line descriptions. Faster to scan, easier to find what you're looking for.
Cloud AI is official
Since v0.5.0, you can use OpenAI, Groq, OpenRouter, or any OpenAI-compatible endpoint instead of running Ollama locally. Set an API key in an environment variable and go. For people without a local GPU, this is often faster and easier.
The GUI launcher and setup wizard now offer both options equally.
Install / upgrade
###b class="inline-flex items-center justify-center relative shrink-0 can-focus select-none disabled:pointer-events-none disabled:opacity-50 disabled:shadow-none disabled:drop-shadow-none border-transparent transition font-base duration-300 ease-[cubic-bezier(0.165,0.85,0.45,1)] h-8 w-8 rounded-md active:scale-95 backdrop-blur-md Button_ghost__BUAoh" type="button" aria-label="Copy to clipboard" data-state="closed"###
pip install --upgrade codedocent
That's it. If you've used it before, same commands work. Architecture mode is --arch. Everything else is the same.
