Another Jumperlink Example
A project log for Jumperlink: A Smarter Way to Connect Electronics
Jumperlink is a board designed to make electronic connections easier to set up, maintain, and share compared to traditional jumper wires.
dylan-zhengdylan zheng 02/23/2026 at 14:480 Comments
(I²C OLED Demo)
In this example, I’ll demonstrate how Jumperlink handles an I²C bus setup.
The module used here is an SSD1306 128×64 0.91" OLED display (I²C version) — a common and inexpensive module easily available from AliExpress and other online suppliers.
This OLED module exposes four signals:
To make the comparison fair, I first built the test setup using traditional jumper wires.
The running result is:
Then I rebuilt the setup using Jumperlink instead of traditional jumper wires.
The signal mapping is configured as follows:
On the left side of Jumperlink, pins L13, L15, L17, and L19 are assigned and connected to the OLED module (VCC, GND, SCL, SDA).
In this example, we also need UART console access for debugging:
Since connector J8 is now occupied by Jumperlink, those UART signals can no longer be accessed directly from the original header. Instead of running extra jumper wires, I simply re-linked them internally within Jumperlink and routed them to different available pins on the left side — in this case, L1 (TXD) and L3 (RXD).
No rewiring. No signal conflict. Just reconfiguration.
Below is the fully linked circuit configuration.
The final wiring is clean, compact, and easy to follow.
As demonstrated, Jumperlink fundamentally improves how two modules are interconnected. It removes cable clutter and replaces it with a structured, software-defined configuration. Connections become faster to set up, easier to maintain, and far simpler to document and share with others.
