Hackaday.io Hackaday.io
Sign up Log in
Thermo/hygro meter and logger
DHT22 based thermo/hygro meter & logger.
miroslav-hancarMiroslav Hancar
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
0 followers
  • Description
  • Details
  • Files 2
    • View all
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
0
0
1
Team (1)
  • miroslav-hancarMiroslav Hancar
Join this project's team
ongoing project
dht22 PIC24 humidity temperature ambient microchip
This project was created on 02/15/2026 and last updated 6 hours ago.
Description
This is a simple device that measures ambient temperature and humidity and stores the readings on an SD card every five minutes. It is based on a DHT22 sensor and a PIC24FJ64GA102-I/SS microcontroller.
Power is supplied via a USB-C connector and a Li-Ion battery, which is charged by the integrated MCP73831 linear charger. The board also includes an accelerometer, allowing the display to rotate as needed - a rather unnecessary feature, but I had a few ADXL345 chips available. For the display, I used an inexpensive 1.8" ST7735 TFT module from AliExpress.
The supply voltage for the MCU and sensor is generated by a TPS631000 buck-boost converter.
The average current consumption is approximately 15 mA and has yet to be optimized.
The SD card library was generated using MCC in MPLAB. The application code was partially written with the help of AI.
Details
Files
DHT22_kicad.zip
x-zip-compressed - 3.70 MB - 02/15/2026 at 16:39
Download
DHT22.X.zip
x-zip-compressed - 1.33 MB - 02/15/2026 at 16:39
Download
Log In/Sign up to comment
Sign up with Github
OR
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Thermo/hygro meter and logger", please tell us the reason.
Send message
Remove Member
