IMPLOTURBOCOMPRESSOR Impulse Turbine 1 Comp Step
·2-Imploturbocompressor, State of the Art Novel InFlow Tech. Impulse Turbine, ·Implo-Ducted, 1 Moving Part Type, One Compression Step
0 followers
·2-IMPLOTURBOCOMPRESSOR State of the Art Novel InFlow Tech: Impulse Turbine, ·Implo-Ducted, 1 Moving Part Type
·2-Imploturbocompressor: Impulse Turbine, ·Implo-Ducted, One Moving Part System Excellence Design, · InFlow Goes from Macro-Flow to Micro-Flow by Implosion-IN/And Inverse-OUT, ·One Compression Step, ·Circular Dynamic Motion. Implosion Way Type, ·Same Nature of a Hurricane Satellite View.
http://stateoftheartnovelinflowtech.blogspot.com
https://padlet.com/gearturbine/un2slbar3s94
gearturbine, imploturbocompressor, .pdf
Latest InFlow Generation State of the Art Novel Tech ·1-Gearturbine Reaction Turbine RotaryTurbo ·2-Imploturbocompressor Impulse Turbine 1 Moving Part
Adobe Portable Document Format - 1.90 MB - 02/23/2026 at 19:26
Preview
Carlos Barrera wrote 02/23/2026 at 19:27 point
Latest InFlow Generation - State of the Art Novel Top Tech: ·1-Gearturbine Reaction Turbine Rotary Turbo, ·2-Imploturbocompressor Impulse Turbine 1 Compression Step:
·1-Gearturbine: Reaction Turbine, ·Rotary-Turbo, Similar System of the Aeolipile ·Heron Steam Device from 10-70 AD, ·With Retrodynamic = DextroGiro/RPM VS LevoGiro/InFlow, + ·Ying Yang Power Type, ·Non Waste Parasitic Looses,
·2-Imploturbocompressor: Impulse Turbine, ·Implo-Ducted, One Moving Part System Excellence Design, ·InFlow Goes from Macro to Micro, ·One Compression Step, ·Same Hurricane Satellite View.
