TritBits
TritBits shows the working of Binary coded numbers, binary 2-complement coded negative numbers and balanced ternary numbers.
0 followers
The switches allow for the input of a 5-digit binary (bit) or ternary (trit) number. A switch set in the up position represents 1, the middle position is 0, and the down position is -1. The corresponding decimal value is shown on the display.
The die LED indicator shows whether binary (two white LEDs) or ternary (three white LEDs) mode is selected. Red and blue LEDs indicate positive and negative numbers, respectively—chosen to evoke 'warm' (positive) and 'cold' (negative) temperatures. The mode is selected using the far-right switch.
A special feature allows the device to demonstrate a ternary relay. To activate this, set the mode switch to the center and the three middle data switches to the down position. The two remaining switches then function as the relay's coil and common.
TritBits.c2d
The Carbide Create V6 source of the CNC file that mills the holes in the casing.
c2d - 73.00 kB - 02/27/2026 at 15:25
Download
TritBits.nc
And the G-code of the CNC file that mills the holes in the casing.
Network Common Data Form (NetCDF) - 63.39 kB - 02/27/2026 at 15:25
Download
Tritbits.ino
The Arduino source code
ino - 18.58 kB - 02/27/2026 at 15:16
Download
UsedMaterialsTritBits.pdf
Used materials
Adobe Portable Document Format - 307.54 kB - 02/27/2026 at 15:14
Preview
