This project shows how to make an AI-powered text-to-speech (TTS) system using an ESP32-C3 microcontroller and an online TTS service (Wit.ai). Instead of trying to generate speech on the ESP32 itself (which has limited memory and processing), this design sends text to an AI service that returns audio, which the ESP32 plays through a speaker. (“Text-to-Speech” converts typed text into spoken words.)
🧠 Why Use Cloud-Based TTS
The ESP32-C3 is a tiny embedded processor with limited RAM and flash. High-quality speech synthesis requires large models and audio processing that can’t realistically run locally. To solve this:
  1. ESP32-C3 connects to Wi-Fi.
  2. It sends text over HTTPS to a cloud TTS API.
  3. The AI service (Wit.ai) generates natural speech and streams audio back.
  4. The ESP32 plays it through an I2S amplifier and speaker.
Advantages
🧩 What You Need
The components needed for ESP32 C3 Text to Speech using AI
ComponentPurpose
ESP32-C3 Dev BoardMain controller (Wi-Fi + GPIOs)
MAX98357A I2S AmplifierDigital audio driver
Speaker (4Ω or 8Ω)Plays the audio
Breadboard + jumper wiresPrototyping
USB CablePower & programming
This setup uses the I2S digital audio interface, which lets the ESP32 transmit streamed audio directly to the amplifier.
🔌 Wiring
Connect the ESP32-C3 to the MAX98357A amplifier:
ESP32-C3 PinMAX98357A PinSignal
GPIO07BCLKBit clock
GPIO06LRCLeft/Right clock
GPIO05DINAudio data
5 VVINPower
GNDGNDGround
Double-check wiring to avoid shorts before powering up.
🛠️ Set Up Wit.ai
  1. Create a free account at Wit.ai.
  2. Create a new app for your project and choose a language.
  3. Go to Settings → HTTP API to get your API Bearer Token.
  4. Save the token securely — don’t hardcode it in public repos.
💻 Install the TTS Library
In the Arduino IDE:
  1. Open Library Manager
  2. Search for WitAITTS
  3. Install the library
This library handles HTTPS communication, buffering, and audio streaming.
⚙️ Upload and Test the Code
Use this example sketch — replace your Wi-Fi SSID, password, and the Wit.ai token:
#include <WitAITTS.h>
const char* WIFI_SSID     = "YourWiFiSSID";
const char* WIFI_PASSWORD = "YourWiFiPassword";
const char* WIT_TOKEN     = "YOUR_WIT_AI_TOKEN_HERE";
WitAITTS tts;
void setup() {  Serial.begin(115200);  delay(1000);    Serial.println("\n--- ESP32-C3 TTS Online Demo ---\n");
  if (tts.begin(WIFI_SSID, WIFI_PASSWORD, WIT_TOKEN)) {    Serial.println("TTS Ready! Type text below:");  } else {    Serial.println("TTS init failed — check credentials.");  }
void loop() {  tts.loop();  if (Serial.available()) {    String text = Serial.readStringUntil('\n');    text.trim();    if (text.length() > 0) {      Serial.println("Speaking: " + text);      tts.speak(text);    }  }
  1. Upload the sketch.
  2. Open Serial Monitor (115200 baud).
  3. Type a sentence and press Enter.
  4. Your ESP32 starts streaming and playing the AI voice audio.
📡 Streaming & Playback Tips
🛠️ Debugging
IssueLikely Cause
No audioWrong wiring or amplifier power
HTTP errorsBad token or Wi-Fi problems
DistortionWeak power or a poor speaker
Check serial logs to trace issues.
🚀 Expand and Integrate
Once you have basic TTS working, you can apply this setup to:
This flexible approach lets your ESP32-C3 speak any text delivered by sensors or user input.
Want more ESP32 Projects? Explore nodes like sensors, speech-to-text, or AI assistants to make your projects listen and speak!
Explore a curated collection of cutting-edge AI Projects and Tutorials that guide makers through real-world machine learning, computer vision, and embedded AI builds step-by-step.
