Quick Start documentation added
A project log for Byte Adder Subtractor: an 8-bit Full Adder
With an accumulator to store one operand. Do binary addition (and subtraction) with the 8-bit Workbenchâ„¢ and Binary (or Hex) Keyboard.
nijssenNijssen 05/08/2026 at 09:140 Comments
Added a Quick Start that shows how addition and subtraction is done.
Attach the 8-bit Workbench™ at the top edge of the Byte Adder Subtractor to display the output of the adder. For input, use the Binary Keyboard or Hex keyboard that can attach at the bottom edge.
Instead, use bread boards to create your own LED output display and input mechanism, e.g. using DIP switches with pull-down resistors. See the schematics of our other products for inspiration how to wire this up using your own parts.
Kits are available now!
