Py-Micro-HIL
Py-Micro-HIL is a modular, lightweight Hardware-in-the-Loop (HIL) testing framework for Python. It provides a unified interface for testing embedded systems, sensors, and communication buses (Modbus RTU, SPI, I2C, UART, GPIO) both on Raspberry Pi hardware and in PC simulation mode.
🚀 Overview
Py-Micro-HIL enables automated functional and integration testing of embedded systems. It supports both real hardware execution on Raspberry Pi and simulated environments on any PC.
With this framework you can:
- Write and organize test suites for hardware peripherals.
- Interface with GPIO, SPI, I2C, UART, or Modbus RTU devices.
- Use mocks for offline or CI/CD testing.
- Generate structured HTML and console reports.
- Integrate easily with pipelines or GitHub Actions.
🔗 Documentation
📚 Full developer and user documentation is available here: ➡️ https://niwciu.github.io/PY_MICRO_HIL
⚙️ Installation
🧰 Option 1 – From PyPI (recommended for most users)
pip install py-micro-hil
🧪 Option 2 – From source (for contributors)
git clone https://github.com/niwciu/PY_MICRO_HIL.git
cd PY_MICRO_HIL
pip install -e .
💡 On your hil test server, you can use the flag --break-system-packages to simplify installation and usage for CI/CD environments:
pip install py-micro-hil --break-system-packages
It will make your life easier when using it in services like GitHub Actions
dependencies
pymodbus, pytest, smbus2, spidev, pyserial
Developer setup
For development and contribution:
git clone https://github.com/niwciu/PY_MICRO_HIL.git cd PY_MICRO_HIL pip install -e .[dev]
🧩 Example usage
1️⃣ Create a configuration file
In the project root for your project hil tests main folder, create a file peripherals_config.yaml , for example:
peripherals:
gpio:
- pin: 17
mode: out
initial: low
- pin: 18
mode: in
Full configuration reference: 📖 Configuration and YAML guide →
2️⃣ Create test files
Create a directory named hil_tests/ and add your test groups there.
Each .py file should start it's name from test and represents a test group.
Example: hil_tests/test_gpio_led.py
from py_micro_hil.assertions import *
from py_micro_hil.framework_API import *
def setup_group(): TEST_INFO_MESSAGE("Setting up gpio led test group")
def teardown_group(): TEST_INFO_MESSAGE("Tearing down gpio led test group")
def test_led_toggle(): gpio = get_RPiGPIO_peripheral() gpio.write(17, 1) TEST_ TEST_ASSERT_EQUAL (1, gpio.read(18))
3️⃣ Run the tests
Before running tests check available options by typing:
hiltests --help
Use the built-in CLI runner:
hiltests --config ./peripherals_config.yaml --test-dir ./hil_tests
Generate a starter group from the editable template without executing any tests:
hiltests --create-test-group gpio_smoke ./hil_tests
If both the YAML configuration and the hil_tests folder are in the same directory,
simply open this directory and run:
hiltests
4️⃣ Generate reports
Py-Micro-HIL can generate both console log files and HTML reports.
Example:
hiltests --log ./reports/log.txt
or
hiltests --html ./reports/report.html
Reports can be customized with name and path. See: Reports and Logging →
💡 Features
- ✅ Unified test structure (
TestFramework,TestGroup,Test) - ✅ Automatic setup/teardown with context isolation
- ✅ YAML-driven configuration system
- ✅ Dynamic test discovery (
tests_group_factory) - ✅ Mock peripherals for PC environment (not RPi)
- ✅ Full logging and HTML report generation
- ✅ Native CLI interface (
hiltests) - ✅ Compatible with Raspberry Pi and Linux hosts
🧰 Supported peripherals & protocols
| Peripheral | Class | Description |
| GPIO | RPiGPIO |
Digital I/O control |
| PWM | RPiPWM, RPiHardwarePWM |
Software and hardware PWM |
| UART | RPiUART |
Serial communication via pyserial |
| I²C | RPiI2C |
SMBus-compatible... |
niwciu
Aneesh Abraham
Peter Walsh
deqing
