ZeroDeck RPI zero interface
RPI zero pcb to be used as a boardgame interfaces
0 followers
This project is part of the electronic boardgame that I'm designing (https://hackaday.io/project/171734-interactive-cell-board-game), but could be used to interface the RPI zero and connect it to other peripherals.
It has an 1.3" OLED SPI display, navigation buttons and RGB LED's to show the player status and the current game phase.
It's is supplied from a connector that it's wired to the boardgame, but really only needs 5V. The boardgame will be also connected by USB to control it.
It also has another connector with supply, SPI and I2C to interface to another board as a second player interface or to an NFC reader that could be used to read a tag in the game pieces.
P010_Interfaz_RPI_BOM.xlsx
Components list
sheet - 11.53 kB - 03/08/2026 at 12:21
Download
P010_Interfaz_RPI_PCB.pdf
Component location
Adobe Portable Document Format - 235.32 kB - 03/08/2026 at 12:20
Preview
P010_Interfaz_RPI.pdf
Schematic
Adobe Portable Document Format - 576.53 kB - 03/08/2026 at 12:20
Preview
