• Let's keep building
    Gera6 hours ago 0 comments
    I'm back and keep writing tons of code.
    Pushed some updates already. Now basics of Modulation Engine is working. Still lots of things to do. Planing to make a huge refactoring and restructuring of project, because i've got tired of jumping across folders and don't like certain things.
  • A little break
    Gera06/27/2026 at 12:37 0 comments
    Guys thanks for following project.
    I've gut burned out a little plus have other things to do in next couple months, so there will be no much progress, but project is not dead!
    Last thing i've added is Step Sequencer in dev branch on github, the logic is bit off(several steps wasn't playing apparently) but i'll get there.
    Cheers
  • Undo-Redo cooking up
    Gera06/03/2026 at 09:14 0 comments
    Undo-Redo capabilities is slowly cooking up in a dev branch of github repo!
    Everything seems functioning well(at least for couple actions), now only need to expand this functionality to all other actions!
  • Saving and Loading
    Gera05/25/2026 at 09:27 0 comments
    At first wanted to create undo-redo system, but quickly figured out that in order to build that i need somehow be able to serialize data, otherwise it would be difficult to restore any state of application.
    So for now simple save and load system is available in dev branch(for now)!
    It is possible to save project and restore it fully without loosing any bits of information(is it?). Thus some issues with restoring colors is there
  • Event logic refactor
    Gera05/03/2026 at 20:18 0 comments
    Made a big refactor of core event dispatch mechanic.
    Now i like it more, because all the data and executable are more tight coupled together, rather than having some sketchy generator that places necessary code to several different files lol:D
    As well it might better fit for future undo-redo logic, but have to test it.
    (somehow broke push support despite that in emulator everything works)
  • Basic support of Push 2
    Gera03/27/2026 at 15:10 0 comments
    Basic support of Ableton Push 2 is there!
    For now dealing with polishing retained GUI architecture(tbh didn't wanted do dive deep in that, but...) to optimize it better so it won't consume all CPU power lol.
    (Pictures will be added later)
