velour stickers
A project log for Soot Sprite Simple Add-On SAO
A studio ghibli inspired simple add on - offering you candy
davedarkodavedarko • 04/18/2026 at 09:48•0 Comments
There were two choices for the shape of the velour stickers: either cut out the perfect circle and then live with the consequences of misplacing them - or cutout the circle after applying a bigger square. I went for the latter, which worked out ok! I'm going over every corner of the PCB with a black marker anyways, to keep the appearance as black as possible. The velour is great for absorbing the light shining on it.
