Picked up a cheap PWM to control the HHO generator cells. This should cut down on heat and electricity usage. The one i am using was sourced online and rated at around 30 amps.
A project log for A Safe(r) HHO gas carburetor for small engines.
No more gas, diesel, or propane. Run it on WATER!
