From the Hawaii
A project log for ESP32 HF QRP FT8 Transceiver
A compact digitally controlled RF 1.8 to 28 MHz platform for HF amateur. DSP mod/demod, integrated FT8 codec and FT8 QSO management.
guido-iw5alzGuido - IW5ALZ 04/06/2026 at 18:440 Comments
20260406 20:48:00 CET
With this receiver connected to my 10-160m mutilband End Fed Long Wire antenna I can receive a lot of FT8 spots from all over the world.
I was the only one, in Europe, to receive a message from KH6DL over the last 24 hours.
My antenna is nothing special as it's located at about 6 meters from the ground, between some buildings. Therefore I think my receiver is not so bad!
