An almost perfect FT8 sequence
A project log for ESP32 HF QRP FT8 Transceiver
A compact digitally controlled RF 1.8 to 28 MHz platform for HF amateur. DSP mod/demod, integrated FT8 codec and FT8 QSO management.
guido-iw5alzGuido - IW5ALZ 04/27/2026 at 07:380 Comments
About 15 days ago I succeeded to follow this almost correct FT8 sequence, but it had a few issues.
Issue
I decoded HB9DGZ answer -05 at 20:05:37 but its transmission was since 20:05:15 till 20:05:27 (my decoding took 10 seconds)
Therefore (waiting for the even slot) I could plan to send R+06 only 1 minute later, since 20:06:30 till 20:06:42.
In the meantime HB9DGZ, not seeing my reply, correctly retried answer -05 since 20:06:15 till 20:06:27 which I decoded at 20:06:36.
At last, at 20:06:30 till 20:06:42 I transmitted R+06
Promptly, HB9DGZ decoded R+06 and transmitted RR73 since 20:06:45 till 20:06:57, which I decoded  7 seconds later at 20:07:04
My upgraded sequence
I answered SV9TLU transmitting JN53                        since 9:33:00 till 9:33:12
At 9:33:15 SV9TLU transmitted -06 to me                    since 9:33:15 till 9:33:27
I decoded -06 before 9:33:30 so I could answer R+06 since 9:33:30 till 9:33:42
Final consideration
Since last SV9TLU CQ (at 9:32:57) till its RR73 (at  9:33:57) elapsed only 1 minute
To see my software improvements, see my my Github
