New FT8MON decoder
A project log for ESP32 HF QRP FT8 Transceiver
A compact digitally controlled RF 1.8 to 28 MHz platform for HF amateur. DSP mod/demod, integrated FT8 codec and FT8 QSO management.
guido-iw5alzGuido - IW5ALZ 07/27/2026 at 08:080 Comments
I forked and modified https://github.com/guido57/ft8mon (by Robert Morris, AB1HL) to obtain a C++ program with reduced memory and processing needs.
My aim is to port it to ESP32-S3 to substitute the actually working decode based on ft8lib.
The testing results on linux (see below) are very encouraging as it performs the same (or slightly better) of WSJT-X.
TEST: 6 hours on 20m band
Benchmark WSJT-X vs PyFT8 vs FT8lib vs FT8mon
using https://github.com/kgoba/ft8_lib/tree/master/test/wav/20m_busy wav test flies
